Pitting , Hole , Defect on printing
zhangxueyou
Re: Pitting , Hole , Defect on printing
Post by zhangxueyou »
Your slicer setting is so bad. Look at the picture, the blue one , which is so bad that I even don't want to continue printing, is printed with your settings, and the green oneis printed with my settings. You can try my settings (attachment), and modify some parameters properly as I suggested you before .
slicer settings(1.75-0.3).rar
(719.11 KiB) Downloaded 602 times
begizmo
Post by begizmo »
Thank for you recommend .
I try to load chinese chess like yours for compare
Overall about pitting , hole and first layer it is better :)
But I see new problem :)
I think my x or y or ? axis will be problem
FullSizeRender (56).jpg (77.15 KiB) Viewed 13754 times
FullSizeRender (57).jpg (77.87 KiB) Viewed 13754 times
Could you seggest me ?
My circle chess it is not round and top surface not smooth .
Thank in advance ^^
zhangxueyou
Did you use my settings? Please print this test file with SD card.
Test_40x30x10_PLA_1.75_0.3.rar
(16.15 KiB) Downloaded 554 times
begizmo
Post by begizmo »
FullSizeRender (59).jpg (80.55 KiB) Viewed 13750 times
FullSizeRender (60).jpg (87.3 KiB) Viewed 13750 times
FullSizeRender (61).jpg (89.21 KiB) Viewed 13750 times
zhangxueyou
PLA or ABS?
begizmo
Post by begizmo »
ABS sir
I already change temperature in your gcode to 230 c
zhangxueyou
Turn off the printer, is it easy to manually move X and Y axes?
begizmo
Post by begizmo »
Yes it easy
zhangxueyou
Tighten the belts a bit, not too much. Maybe they are too loose.
email4walker
Post by email4walker »
Hi begizmo,
I used to get bad prints like yours when I first started. It is a settings issue. Try lowing your print speed on the perimeter. I use MatterControl for my 3D printing software/interface. How it works is not really better than the other one, but it has a way better visual look. Also, you can click the help on it and it tells you what every setting does. No more guessing what a setting will do. Either way, try slowing down your print speed. That will help some. Thanks.
Oh yeah, it is free:
http://www.mattercontrol.com/
