Geeetech A30M profile setting for Simplify3D and Repetier-Host
Re: Geeetech A30M profile setting for Simplify3D and Repetier-Host
Please guide more
You can slice the model and import it into the color mixer for color mixing.
If you want to print mixed colors, you can refer to the method in the video to import the model
Different parts of the
Then select different parts and choose different extruders to set up,
Check the color mixing ratio on the screen. If it is 100: 0, it will also affect the printer output.
The mixer worked somewhat. Most I needs to use in a single print, two colors individually In different parts, not in a mix!
please check our request. We cannot print models 1 (Extruder_1 selected) and 2(Extroder_2 selected). The program is configured with the settings stated in the video.
- Our output is one color. Or the second color is not printed at all.
- Our Extruder_1 works well. Our Extroder_2 alone works well. No hardware problem.
- Our problem is how Extruder_1 and Extruder_2 work together.
- We know that it takes some time for the filament to change.
We will discuss
and give you feedback.
Thanks, I'm waiting for your reply
Our try (today), please check
uncheck : printer has mixing extruder
but you may need to play retraction and purge tower size
i did not try. you will need to test
- 2extrudr printing.png (510.54 KiB) Viewed 10012 times
Our subject needs technical check. The problem is not solved
hello,
Printing multiple files at once (repetier-host)
Set multiple print heads in settings Set different files to different extruders
- QQ图片20200222165009.png (363.39 KiB) Viewed 9690 times
Hi, please send us this model for test
