Extruder fan
Extruder fan
I have bought a Rostock G2s.
All works well, but extruder fan doesn't. A solution ?
Where can i find last firmware ?
(Sorry for my english)
Re: Extruder fan
Sorry,
It is hotend fan who doesn't work.
My e-mail for firmware please: serge-aubert@laposte.net
Thank you for answer
Re: Extruder fan
I made a mistake: it is hot hend fan who doesn't work, and it is connected on PWM.
Both extruders turn wrong way (filament goes out) what to do ?
my email for firmware please: serge-aubert@laposte.net
Thank you for your answer
Sergio
Sergio
rxn123talon
Re: Extruder fan
I am having the same issue with the hot end fan on a G2S. Was there a solution to this?
Re: Extruder fan
No sorry. No answer for the moment.rxn123talon wrote:I am having the same issue with the hot end fan on a G2S. Was there a solution to this?
Re: Extruder fan
hot end fan (pwn-fan) is controled by g-code.so it's running according to the code.
Re: Extruder fan
Re: Postby Eric » Tue Aug 04, 2015 11:14 am
my extruder fan does not turn ever - result overheating and melting of hotend. When does g-code turn this on?
Where in g-code to correct this?
rxn123talon
Re: Extruder fan
I use the settings in SLIC3R to turn the fan on.. It's in one of the tabs (I'm not in front of my computer with the program). I have it set to always turn the fan on and keep it at 100.
Re: Extruder fan
Thanks for tip but i tried that and fan never turns on. Is your fan two or three wire. I.e. yellow wire as well to fan?
Re: Extruder fan
The hotend fan only has two wires,as pic bellow. you can swap the fan with coldend fan to check if the fan was dad or not .
- fan.png (668.98 KiB) Viewed 15158 times
