Power supply not working
Coffeeownsyou
Post by Coffeeownsyou »
All wires are connected correctly according to pictures and instructions given for the geeetech prusa i3 pro b.
Nothing powers whilst plugged into the mains only the light on the power switch.
The lcd and motherboard turn on when I plug it into my laptop but I can't print as there isn't enough power to run it.
I'm pretty sure the power supply is faulty and not working.
Re: Power supply not working
Coffeeownsyou wrote:All wires are connected correctly according to pictures and instructions given for the geeetech prusa i3 pro b.
Did you measure the DC output of your PSU with a multimeter?Is it 12V?
Also,could you attach some pics about your wiring on the PSU?
Coffeeownsyou
I have not tested with a multimeter yet, but here is a picture of the wiring.
Coffeeownsyou
i have yet to test it with a multimeter but here is a picture of the wiring to the PSU.
Coffeeownsyou wrote:I have not tested with a multimeter yet, but here is a picture of the wiring.
You can test the voltage between the red wiring and the black one when you power on,so as to confirm if the PSU is a bad one.
Attach the pic of multimeter displaying plz.
Coffeeownsyou
Coffeeownsyou
Here is the multimeter test on the red and black wiring.
Contact the seller for a replacement plz.
