Geeetech A10 problem solving instruction
jojudima
Post by jojudima »
The extruder step motor moves back and forth, but the filament does not advance.
Disassembled, the motor shaft moves smoothly.
I have exchanged it for the one on the Y-axis but the problem persists.
For this reason, no filament comes out and I cannot print.
Model Geeetech A10
Marlin 1.1.8
2017-12-25
Board info
GT2560 V3.1
FW ver 1.5
HW ver 5.00
Regards,
Re: Geeetech A10 problem solving instruction
Hi, my friend.
I think it may be that the feeder screw on the motor is too tight to feed normally, you can adjust it.
You can also provide pictures or videos, I will better judge for you.
jojudima
Post by jojudima »
With the feeder screw unmounted, does the same.
See video attached.
Best regards,
VID20200510115709_s01.zip
(581.55 KiB) Downloaded 239 times
Hi,you can check whether the motor cable is connected well, or replace the drive to see if there is a problem with the drive.
jojudima
Post by jojudima »
Hi, the wire is properly conected and i replaced the drive yesterday for the one is in the Y-axis with the same failure.
Regards.
jojudima
Post by jojudima »
Do you any solution for this issue?
It is a little bit urgent.
Regards,
Hi,have you replaced the good driver?
if so,there should be a problem with the motherboard.
You can contact the salesman to replace the motherboard.
jojudima
Post by jojudima »
Hi, I bought it at Shenzhen Getech Technology Co., Ltd. and was delivered by Amazon in december 17th.
Is there any Service in Spain?
As far as I know it is under warranty period, can you send me the motherboard?
Regards,
jojudima
Post by jojudima »
Invoice attached.
Invoice.zip
(78.39 KiB) Downloaded 245 times
Hi,please contact the salesman on the platform directly.
